Hello Guest it is November 13, 2026, 05:58:40 PM
Author Topic: How to create Special Character Symbol "B" as a Beta on mach3 ?  (Read 13828 times)
I want to create a Symbol letter "B" as a beta but I can not find it on mach3 plugin wizard.
how to create it on mach3 ?
Thank you
Re: How to create Special Character Symbol "B" as a Beta on mach3 ?
« Reply #1 on: June 14, 2011, 08:56:25 PM »
Use the WRITE wizard to generate the Gcode.
« Reply #2 on: June 14, 2011, 09:05:15 PM »
I'm using the WRITE Wizard, are you sure I can do the "B" beta symbol character on that "write" wizard ?
or can I use any Symbol Font ? on that "write" ?
thank you
  •  9,377 9,377
« Reply #3 on: June 15, 2011, 12:29:21 AM »
I don't think you can do that as I have never actually seen the β character in any of the write wizard fonts.
It should be available in most CAD/CAM programs, that would perhaps be the way to go.
« Reply #4 on: June 15, 2011, 08:44:07 AM »
oh Well I guess it does not create β
thanks
« Reply #5 on: June 15, 2011, 09:40:20 AM »
USE DeskEngrave( FREE)  and find a font that HAS the Beta Character.
DESKENGRAVE, One of the BEST free things you can have in your MACH TOOL BOX(;-)
« Reply #6 on: June 15, 2011, 04:23:23 PM »
Have few Beta's to play with.... ;)
Notice the difference in the number lines between the two Gcode's as one is done with arc's ( drawn quickly ) and one is done with lines ( from DeskEgrave ).
Deskengrave is quick and easy but if you get picky then the straight line code may not suite you.
« Last Edit: June 15, 2011, 04:30:41 PM by RICH »
