Mach Discussion => General Mach Discussion => Topic started by: calico on June 14, 2011, 08:25:51 PM
I want to create a Symbol letter "B" as a beta but I can not find it on mach3 plugin wizard.
how to create it on mach3 ?
Thank you
Use the WRITE wizard to generate the Gcode.
I'm using the WRITE Wizard, are you sure I can do the "B" beta symbol character on that "write" wizard ?
or can I use any Symbol Font ? on that "write" ?
thank you
I don't think you can do that as I have never actually seen the β character in any of the write wizard fonts.
It should be available in most CAD/CAM programs, that would perhaps be the way to go.
oh Well I guess it does not create β
thanks
USE DeskEngrave( FREE) and find a font that HAS the Beta Character.
DESKENGRAVE, One of the BEST free things you can have in your MACH TOOL BOX(;-)
Have few Beta's to play with.... ;)
Notice the difference in the number lines between the two Gcode's as one is done with arc's ( drawn quickly ) and one is done with lines ( from DeskEgrave ).
Deskengrave is quick and easy but if you get picky then the straight line code may not suite you.
