Hello Guest it is November 13, 2026, 05:04:25 PM
Author Topic: Remote USB display with Modbus  (Read 91169 times)
Re: Remote USB display with Modbus
« Reply #20 on: June 15, 2011, 05:29:48 PM »
That worked it said Hello on the LCD!!!!
Fred
OK if you can write to it with Hyperterm them all we should have to do is find out the Comport settings that HT used.
Then try setting up the MCAH port the same.   Then we can start with something simple like
SendSerial "Hello" and see what happens.
"Gravity, its not just a good idea its the law"
« Reply #21 on: June 15, 2011, 06:24:56 PM »
OK see I told ya just ONE small itsiy tiny step away. Now we need to figure out the matrix
Try sendserial "abcdefghijklmnop"      that would be 16 charectors or 1 full line.
(;-)TP
« Reply #22 on: June 15, 2011, 06:44:53 PM »
OK, that worked as well but I found out it only worked when I run the VB script manually in the editor. If I save it as macropump.m1s and start Mach it does not show up. Ans yes I do have run macro pump checked in Comfig. Is there something in ports and pins that I missed?
Fred
(;-)TP
« Reply #23 on: June 15, 2011, 07:12:01 PM »
HUM, no if it runs in vb script it should run as a macropump. The macropump is just a vb script ran 10 times per second all the time.
OK try this  sendserial" ?x0,?y1" & "hello"                it should put hello on the second line down from the top
« Reply #24 on: June 15, 2011, 09:05:13 PM »
It worked manually OK it put it second line down one space over from the left.
Fred
« Reply #25 on: June 15, 2011, 09:58:36 PM »
OK one last thing for today,
Sendserial " abcdefghijklmnopqrstuvwxyz"  Lets see if it will line wrap.  IF it does OK then send the original SCript that had the single string to it from the editor. If that works let me know.
« Last Edit: June 15, 2011, 10:00:40 PM by BR549 »
« Reply #26 on: June 16, 2011, 09:41:45 AM »
Sorry I did not get this untill this morning, when I get home tonight I will try it. Also is this the other one you wanted me to try?
XV = "X: " & Format (Getdro(0) , "+000.0000;-000.0000") & "    "
YV = "Y: " & Format (Getdro(1) , "+000.0000;-000.0000") & "    "
ZV = "Z: " & Format (Getdro(2) , "+000.0000;-000.0000") & "    "
AV = "A: " & Format (Getdro(3) , "+000.0000;-000.0000") & "    "
MS = "?Y0,?X0"
SendSerial "" &MS &XV &YV &ZV &AV
« Reply #27 on: June 16, 2011, 01:06:35 PM »
HIYA FRED,   YEP that is the one BUT less make a slight mod and send this. I removed the comma between the ?x and ?y
MS = "?Y0?X0"
« Reply #28 on: June 16, 2011, 06:16:39 PM »
OK, we do have line wrap. I tried the scrip and it is close here is what we have now.
« Reply #29 on: June 16, 2011, 07:47:59 PM »
I also figured out why the macro was not running, it was in the wrong folder. It now runs when I start Mach but everything scrolls across the LCD?
