Hello Guest it is November 13, 2026, 05:03:50 PM
Author Topic: Remote USB display with Modbus  (Read 91168 times)
Re: Remote USB display with Modbus
« Reply #30 on: June 16, 2011, 08:20:15 PM »
I was able to get it to stop scrolling by adding this to this line.
MS = "?Y0?X0?a?G420"
This is what I have now and the curser stays where you see it and blinks.
"Gravity, its not just a good idea its the law"
« Reply #31 on: June 16, 2011, 08:24:14 PM »
Great all you have to do now is adjust the spaces at the end of each line to make it wrap to the proper starting spot.  ADD more spcaes between the "     " you do it with the space bar.  Iwas thinking you had a 4x16 dispaly it is 4x20 so add 4 spaces to each "     "
« Last Edit: June 16, 2011, 08:27:05 PM by BR549 »
« Reply #32 on: June 17, 2011, 06:24:01 AM »
That did it!!!!! You are the man I can`t thank you enugh for all your help this is so great.  :o
 ;D ;D ;D ;D ;D ;D
« Reply #33 on: June 17, 2011, 09:39:13 AM »
Fred it was not just me YOU are the MAN. (;-) You ORIGINATED teh idea and kept at it until you worked it out. I just bumped you back on track a couple of times.
NOW could you write a little summary of what ALL you did to make it all work THEN post it HERE so if people do a search they can find the info
Great JOb, (;-) TP
« Reply #34 on: June 18, 2011, 11:57:49 AM »
Great JOb, (;-) TP
Yes I will.
« Reply #35 on: June 18, 2011, 01:49:08 PM »
