Hello Guest it is October 21, 2026, 12:54:48 AM
Author Topic: Set offset in Klaus' camera plugin?  (Read 10526 times)
« on: June 11, 2011, 04:11:57 AM »
Hello everybody,
I just installed Klaus' Camera Plugin. Everthing works fine except that I can't figure out how to set the offset and that the coordinates don't show up when the box in the video window is checked. Any ideas?
Otherwise many thanks for the great work Klaus!
Re: Set offset in Klaus' camera plugin?
« Reply #1 on: June 11, 2011, 07:25:14 AM »
Hi Dave,
after start of Mach3 go to Config->Config plugins WebCamPlugin CONFIG. In that dialog you can set the X and Y-offset. Once the offset is set, open the "Dialog Settings" dialog on bottom of the camera screen. In that dialog you'll see the button "move offset". This button is only enabled, if Mach3 is not reset.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: June 11, 2011, 07:37:28 AM »
Cool!
Works like a charm.
Thanks again Klaus
