Hello Guest it is November 13, 2026, 09:09:19 PM
Author Topic: Printer Port Problems  (Read 69282 times)
Re: Printer Port Problems
« Reply #50 on: June 10, 2011, 12:05:15 PM »
One other thing,Try turning OFF the networking option and see IF the machine runs better.
Offline docltf
  •  354 354
« Reply #51 on: June 10, 2011, 01:05:09 PM »
have you tried to reset your mother board by pulling the battery out and waiting 10 min.
go into cmos at boot select use default setting and nothing else then reboot.use safe mode when windows comes up it should reconfig a few things.this will assign a new loading order to the drivers.don't use the select high perf setting in cmos until later.good luck!
bill
Offline bajadave
  •  61 61
  • If It isn't Broke, Then See How It Works
« Reply #52 on: June 10, 2011, 07:20:00 PM »
Disabled the onboard Network.. no good... Did the cmos battery.. no good... Joined the mach5 masters site and d/l the file to optimize XP.. Took the day and did everything on the list.. Seems to made things worse.. I know everyone has helped and must be frustrated like I am... At this point with so many changes to the system I decided to Blow it all off AGAIN and do a fresh install AGAIN... Perhaps something screwed up with the last install... Thanks Guys for all the help..... Forum here rocks and so do the people...
« Reply #53 on: June 10, 2011, 08:13:35 PM »
AH MAN, Just when we were getting close, ONE tiny little fix away (;-) LOLOLOLOL
Offline bajadave
  •  61 61
« Reply #54 on: June 11, 2011, 04:41:40 PM »
Glad MY work space has room for 2 computers... Did not work!!!!! Decided to bring the other PC to the shop and use it to design and the older one to run Mach... Thanks a Ton Guys but I don't think we were just ONE tiny little fix away.... LOLLOLOLOL   Would of been nice, But wasn't happening.... Thanks Again....
« Reply #55 on: October 03, 2011, 04:54:42 AM »
If you have been running in demo can you load the driver later?
I am unable to get a connection thru the LPT port
  •  9,377 9,377
« Reply #56 on: October 03, 2011, 05:32:08 AM »
Rupert,
Run 'Driver Test.exe' from the Mach folder - this should ensure the drivers are loaded.
