Hello Guest it is November 22, 2026, 02:28:34 PM
Author Topic: camworks post processor  (Read 13890 times)
« on: May 30, 2011, 11:07:09 PM »
I have searched the forum and it doesn't look like anyone is using camworks.
we are using solidworks 2011 with camworks 2011 and a Mikini 1610L mill running Mach 3.
Does anyone have a post that works?
Our VAR has so far been unable to get us something that works.
I've had the most problems anytime a g41 is output. Everything steps through fine, but Mach will run completely erratic with some moves even going backwards.
Any help is appreciated.
Re: camworks post processor
« Reply #1 on: May 31, 2011, 09:12:01 AM »
Any of the early Fanuc posts should get you started. Camworks should be able to provide you with a proper post.
