Hello Guest it is November 13, 2026, 12:40:30 PM
Author Topic: Sound Logic Encoder Interface anyone?  (Read 31838 times)
Re: Sound Logic Encoder Interface anyone?
« Reply #10 on: December 31, 2006, 07:59:59 AM »
Being able to reset and the dro resetting to the encoder position would be a great feature.
« Reply #11 on: December 31, 2006, 08:02:50 AM »
Thanks Brian,
     I know it wouldn't be closed loop with the pause but God it would be close  :). Just thinking out loud.
« Reply #12 on: December 31, 2006, 10:00:11 PM »
We have it working and if there is more then .008 following error the motors are stopped :) I will add the code to make it upload the encoder position soon... Should have time tomorrow to work on it.
www.newfangledsolutions.com
www.machsupport.com
« Reply #13 on: January 01, 2007, 06:28:47 AM »
Brian,
What will the difference be between the plugin vs the current macro pump that is used?
Thanks,Joe.
« Reply #14 on: January 01, 2007, 08:04:43 AM »
It will update at 1/40 of a sec and will not need to have a special screen set or macro pump. You also will be able to set the following error.
www.machsupport.com
« Reply #15 on: January 01, 2007, 08:41:03 AM »
Sounds great.My customer has showed serious interest in 1 of these boards,any idea how long before the plugin is available?BTW the shuttle express works fantastic.My customer has 14 late model mazak machines and 1 hurco with mach3 that i just retrofitted.Everyone that has seen this machine run is blown away including the mazak service guys.Keep up the good work.
Joe.
« Reply #16 on: January 01, 2007, 10:35:46 AM »
^  You might be doing a retro on all 14 machines soon!
