Hello Guest it is October 21, 2026, 12:23:05 PM
Author Topic: Reset = E-stop?  (Read 71774 times)
Re: Reset = E-stop?
« Reply #10 on: June 05, 2011, 07:23:48 AM »
Perhaps 1003 is feedhold and not stop?
Re: Reset = E-stop?
« Reply #11 on: June 05, 2011, 07:56:20 AM »
1003 I believe is Stop and should really only be used when all motion has stopped, so likely better to use OEM 1001 (feedhold) first and have a
While IsMoving()
Wend
between the two
Re: Reset = E-stop?
« Reply #12 on: June 05, 2011, 01:13:40 PM »
I found the problem, possibly an error with mach, when issueing 1003 controller goes into e-stop, therefore the only way to retrieve would be to "reset" since issueing 1003 a second time doesn't help. When the button is assigned directly as stop instead of via script then it stops only, doesn't go into estop.
« Last Edit: June 05, 2011, 01:15:47 PM by jrobson »
Re: Reset = E-stop?
« Reply #13 on: June 05, 2011, 01:57:41 PM »
HUM 1003 does not go into reset/estop here when used in a script.
So you want a script that will safely stop the program and then rewind and clear messages??
Hood is correct that you should do a Feedhold/pause and the While ISmoving Wend then issue the stop. Otherewise you can loose position.
I have a script that will do what you want I will look it up and test it.
Just a thought(;-) TP
Re: Reset = E-stop?
« Reply #14 on: June 05, 2011, 02:11:26 PM »
Can you post teh code you tried so I can test it here?
Thanks (;-) TP
Re: Reset = E-stop?
« Reply #15 on: June 05, 2011, 03:29:03 PM »
Don't mind losing position, however, "DoOEMButton(1003)" by itself causes estop to activate, even just that line by itself. Like I said before if I hit the button when it isn't coded and given function stop standard code 3 it works just fine, it stops, doesn't rewind though, but it stops without going into e-stop.
I've tried the code, still didn't work, even if the program is not executing, just by pressing the button with code 1003 causes e-stop to activate.
Re: Reset = E-stop?
« Reply #16 on: June 05, 2011, 03:51:33 PM »
You can see the attached screen.
Re: Reset = E-stop?
« Reply #17 on: June 05, 2011, 03:53:38 PM »
F10 is shortcut for start when in the auto section.
Re: Reset = E-stop?
« Reply #18 on: June 05, 2011, 04:29:23 PM »
Do you have servos? Do they have a fault output that you have going to Mach? If yes then that will be why you are getting the E-Stop triggering when you do OEM1003
Re: Reset = E-stop?
« Reply #19 on: June 05, 2011, 06:20:51 PM »
Just tested the 1003 here and it does not trip a reset here.
