Hello Guest it is November 09, 2026, 06:35:44 AM
Author Topic: Do step & direction wires need to be shielded cable?  (Read 9887 times)
Offline Jackal
  •  173 173
« on: May 23, 2011, 04:15:42 PM »
 It's time for the step & direction wires from the B_O_B to the Geckos.
Do these need to be shielded cable?
If so, what gauge?
I have some of the shielded cable  left from the factory wiring. It's not very heavy gauge.
JAckal
Everything is bio-degradable if you run over it enough with a lawnmower.
Re: Do step & direction wires need to be shielded cable?
« Reply #1 on: May 23, 2011, 04:42:29 PM »
Dont need to be heavy, not sure of your USA gauges but just signal wiring is needed but definitely shielded in my opinion.
Offline Jackal
  •  173 173
« Reply #2 on: May 23, 2011, 04:44:11 PM »
Would encoder wire work?
JAckal
« Reply #3 on: May 23, 2011, 05:20:30 PM »
Would be perfect, encoder signals and step/dir signals are basically the same thing :)
