Hello Guest it is October 20, 2026, 05:45:05 PM
Author Topic: Waterjet CV  (Read 10618 times)
Waterjet CV
« on: May 19, 2011, 08:43:56 AM »
What should the CV settings be for a waterjet machine?
Re: Waterjet CV
« Reply #1 on: May 20, 2011, 08:12:00 AM »
If your cutting really thin stuff at high speeds use "exact stop" to prevent corner rounding.
I use "CV" for all the rest.
 Jay
Re: Waterjet CV
« Reply #2 on: May 20, 2011, 08:51:18 AM »
Do you have to call up cv mode from the g-code or is it on all the time?
Re: Waterjet CV
« Reply #3 on: May 20, 2011, 01:24:21 PM »
CV mode is set on General Config page but can be overridden by code. If your code has G64 in it then that is CV mode, if your code has G61 then it will be Exact Stop. You can obviously change at will during a run of code by having G61 or G64 in your code at the relevant points.
