Hello Guest it is November 10, 2026, 02:34:53 AM
Author Topic: Run a script when Mach loads  (Read 9045 times)
Offline ftec
  •  88 88
« on: May 12, 2011, 08:18:24 AM »
Is it possible and how to run a macro from file when Mach loads?
/Risto
Re: Run a script when Mach loads
« Reply #1 on: May 12, 2011, 10:30:41 AM »
Not sure, but you can add it to the initialization string and run it the first time you press reset.
Offline ftec
  •  88 88
« Reply #2 on: May 12, 2011, 10:51:43 AM »
Wonderful workaround, thanks Gerry!
/Risto
« Reply #3 on: May 12, 2011, 12:12:53 PM »
HI,
If you are using a recent mach release, there is a script that is loaded (if it is present) whenever mach loads a screen set.
For more info get the programmer's ref manual from here
http://machsupport.com/docs/Mach3_V3.x_Macro_Prog_Ref.pdf
and look up ScreenSetLoad.
www.CalypsoVentures.com
Offline ftec
  •  88 88
« Reply #4 on: May 12, 2011, 01:03:25 PM »
Could be what I'm looking after, Thanks Dave!
/Risto
