Hello
Guest
it is
November 10, 2026, 01:56:13 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
VB and the development of wizards
Run a script when Mach loads
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Run a script when Mach loads (Read 9040 times)
ftec
88
on:
May 12, 2011, 08:18:24 AM »
Is it possible and how to run a macro from file when Mach loads?
/Risto
Logged
ger21
6,295
Re: Run a script when Mach loads
Reply #1 on:
May 12, 2011, 10:30:41 AM »
Not sure, but you can add it to the initialization string and run it the first time you press reset.
Logged
ftec
88
Reply #2 on:
May 12, 2011, 10:51:43 AM »
Wonderful workaround, thanks Gerry!
/Risto
Logged
DaveCVI
551
Reply #3 on:
May 12, 2011, 12:12:53 PM »
HI,
If you are using a recent mach release, there is a script that is loaded (if it is present) whenever mach loads a screen set.
For more info get the programmer's ref manual from here
http://machsupport.com/docs/Mach3_V3.x_Macro_Prog_Ref.pdf
and look up ScreenSetLoad.
Logged
Author of the MachStdMill Extensions for Mach3
www.CalypsoVentures.com
ftec
88
Reply #4 on:
May 12, 2011, 01:03:25 PM »
Could be what I'm looking after, Thanks Dave!
/Risto
Logged
Print
Pages:
1
Go Up
« previous
next »
