Hello Guest it is November 10, 2026, 05:49:49 AM
Author Topic: How to change the DRO for RPM?  (Read 34393 times)
« on: May 05, 2011, 04:37:23 PM »
I have a VFD with an encoder, and it has a 2 speed gear box (high/low). The problem I have is the RPM readout. I use a DSPMC from Vital Systems. In the plugin for the DSP it has a box for spindle encoder count. I have this set perfect for High gear, but when I switch to Low gear the count is off. It's only cosmetic, since the spindle spins at the speed it is commanded to, but is there a quick fix to fix this? Maybe with Brains?
Aero
Re: How to change the DRO for RPM?
« Reply #1 on: July 19, 2011, 07:53:26 AM »
This should be possible using a switch or push button input or even a User DRO to set which formula you use to calculate rpm from your signal and writing it to the DRO.
If you watch the tutorial and have a play with the brain editor you should soon work it out. The brain viewer in Mach is handy for trouble shooting to watch the brain work in real time.
« Reply #2 on: August 08, 2011, 07:50:32 AM »
The best fix would be mount your encoder to the spindle output 1:1, normally the counts value is the number of encoder counts for 1 turn of the encoder.
Andrew
Andrew
MachMotion
« Reply #3 on: August 10, 2011, 05:37:44 PM »
Aero
If you set up the gears in the pulley selection dialog it will correct for the different.
It should be possible to connect a switch to the gear change mechanism and have Mach3 change the dros without have to manually go in and select the different "pulley"
Mike
