Hello Guest it is November 22, 2026, 02:25:03 PM
Author Topic: Mach3 not performing M03 function  (Read 9045 times)
« on: May 02, 2011, 01:50:29 AM »
Running a Plasma using M03 to O/P1 to control Hypertherm45 to initiate arc, can manually strike arc by toggling spindle on/off control or F5 but on running Gcode and even single stepping code, at M03 op nothing happens machine will perform as if it was cutting  any suggestions welcome
Re: Mach3 not performing M03 function
« Reply #1 on: May 02, 2011, 09:38:31 AM »
Double check your M3 macro to make SURE the start code is there  DoSpinCW()
Just a thought, (;-) TP
