Hello Guest it is October 21, 2026, 07:57:00 AM
Author Topic: Move off Home Switch  (Read 10492 times)
« on: April 26, 2011, 02:43:48 PM »
My Z & Y axis home switches suddenly stopped working ( they are wired in series ). They used to home with Z first and it would move off switch and Y would home and move off switch. Now - Z mvoes first and hits switch and does not move off. Y will not home. Then the X axis will home and move off switch ( X axis is wired seperatley.
Any idea's?
Will
Re: Move off Home Switch
« Reply #1 on: April 26, 2011, 06:37:01 PM »
I'm guessing you may be picking up a little noise now.  Have you tried to add any debonce and see if that helps?  Moved any wires around or anythng to induce noise?
« Reply #2 on: April 27, 2011, 12:26:59 PM »
You are ABSOLUTELY CORRECT!
Wow, thank you very much. I spent 3 hours fighting the problem before I desperately posted for help.
Thanks again
Will
« Reply #3 on: April 27, 2011, 03:22:05 PM »
No problem Will, glad you got it.
