Hello
Guest
it is
November 14, 2026, 08:18:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
halfmoon instead of circle
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
Go Down
Author
Topic: halfmoon instead of circle (Read 81454 times)
ostie01
628
Re: halfmoon instead of circle
Reply #10 on:
April 26, 2011, 02:18:22 PM »
I would try to do a fresh install of mach3
I think sometime it gets all mixed up and need to be re install.
Jeff
cheech669
34
Reply #11 on:
April 26, 2011, 03:09:02 PM »
Thank you all for your help, it's much appreciated.
I reinstalled mach3 and it's almost there but still the motors aren't quite doing what they should.
my y+ and a+ will not work unless an other direction is introduced first.
cheech669
34
Reply #12 on:
April 27, 2011, 07:18:36 AM »
so this morning I turn on the computer and I get these results.
z+ = nothing moves
z- = a+ y+ x+
y+ = x+
y- = a- y-
x+ = x+
x- = x-
it's like there's a ghost in the machine set on pissing me off
cheech669
34
Reply #13 on:
April 27, 2011, 09:06:26 AM »
I just reinstalled mach3 again set everything up again. Now I'm back to not having my y+ and a+ move untill my x- moves first
docltf
354
Reply #14 on:
April 27, 2011, 09:58:49 AM »
uninstal mach3 - delete mach 3 folder - go to device and uninstall prnt and com ports - shut down - unplug
snatch the battery out of the motherboard for about 10 min.
load the default settings then look your cmos settings over.
restart and let win find the ports - make sure they all come back.
then put mach back
bill
cheech669
34
Reply #15 on:
April 27, 2011, 01:52:27 PM »
All that did was waste a huge part of my day. Any more suggestions?
cheech669
34
Reply #16 on:
April 27, 2011, 03:47:57 PM »
Ok so here what is happening.
y+ will not move after x+ has moved any distance untill x- has moved any distance, then y+ will move any distance
ostie01
628
Reply #17 on:
April 27, 2011, 05:49:43 PM »
Can you post picture of your setup, The electronic part I mean
Look to me that they're something wrong in the setup pin.
Have you tried to set direction to active low.
Jeff
cheech669
34
Reply #18 on:
April 28, 2011, 07:34:31 AM »
I hope this is what you wanted. Since this was a retrofit the wiring was very idiot proof as everything was already hooked up working and labeled. If anything else is needed please ask and it will be done
Tweakie.CNC
9,377
Super Kitty
Reply #19 on:
April 28, 2011, 07:51:51 AM »
May be an idea at this stage to just try another PC, just in case it is your PC which is at fault.
Print
Pages:
1
2
3
4
5
6
7
Go Up
« previous
next »
