Hello Guest it is November 14, 2026, 08:08:29 PM
Author Topic: halfmoon instead of circle  (Read 81451 times)
Re: halfmoon instead of circle
« Reply #10 on: April 26, 2011, 02:18:22 PM »
I would try to do a fresh install of mach3
I think sometime it gets all mixed up and need to be re install.
Jeff
« Reply #11 on: April 26, 2011, 03:09:02 PM »
Thank you all for your help, it's much appreciated.
I reinstalled mach3 and it's almost there but still the motors aren't quite doing what they should.
my y+ and a+ will not work unless an other direction is introduced first.
« Reply #12 on: April 27, 2011, 07:18:36 AM »
so this morning I turn on the computer and I get these results.
z+ = nothing moves
z- = a+ y+ x+
y+ = x+
y- = a- y-
x+ = x+
x- = x-
it's like there's a ghost in the machine set on pissing me off
« Reply #13 on: April 27, 2011, 09:06:26 AM »
I just reinstalled mach3 again set everything up again.  Now I'm back to not having my y+ and a+ move untill my x- moves first
Offline docltf
  •  354 354
« Reply #14 on: April 27, 2011, 09:58:49 AM »
uninstal mach3 - delete mach 3 folder - go to device and uninstall prnt and com ports - shut down - unplug
snatch the battery out of the motherboard for about 10 min.
load the default settings then look your cmos settings over.
restart and let win find the ports - make sure they all come back.
then put mach back
bill
« Reply #15 on: April 27, 2011, 01:52:27 PM »
All that did was waste a huge part of my day.  Any more suggestions?
« Reply #16 on: April 27, 2011, 03:47:57 PM »
Ok so here what is happening.
y+ will not move after x+ has moved any distance untill x- has moved any distance, then y+ will move any distance
« Reply #17 on: April 27, 2011, 05:49:43 PM »
Can you post picture of your setup, The electronic part I mean
Look to me that they're something wrong in the setup pin.
Have you tried to set direction to active low.
Jeff
« Reply #18 on: April 28, 2011, 07:34:31 AM »
I hope this is what you wanted.  Since this was a retrofit the wiring was very idiot proof as everything was already hooked up working and labeled.  If anything else is needed please ask and it will be done
  •  9,377 9,377
« Reply #19 on: April 28, 2011, 07:51:51 AM »
May be an idea at this stage to just try another PC, just in case it is your PC which is at fault.
