Hello Guest it is November 13, 2026, 05:00:18 PM
Author Topic: Mach3 TCP/IP Modbus config setup  (Read 20052 times)
« on: April 22, 2011, 08:51:41 PM »
Here is a screen shot of the current PKE, modbus tcp config window.
Note: There are some issues with, PWM, and MPGs, that the registers from the PKE will need to be cut down to 16 bits from 32, He is working on that.
Here is a screen shot.
scott
Re: Mach3 TCP/IP Modbus config setup
« Reply #1 on: March 01, 2013, 10:24:58 AM »
How did the modbus tcp/ip doing with mach 3.  I am just starting my journey on this configuration and am in the dark so any help would be great.  I was wanting to stop, start, vary speed, maybe monitor load amperage of spindle.  I am running a VFD drive that has the capability to us modbus tcp/ip over ethernet, or modbus rtu via rs485.  Any help would help would be great.
Brooks Nelson
