Hello Guest it is September 21, 2026, 03:34:37 PM
Author Topic: Home switches!!  (Read 13030 times)
Home switches!!
« on: April 19, 2011, 06:24:32 PM »
Hi to all, i got a question!!
All my home switches are working fine and when i hit  Ref ALL HOME works fine also, but what i can do to move the y axis littlebit more far from the home sw when the REF ALL HOME is in process in that axis!
Thanks!!
Offline olf20
  •  325 325
Re: Home switches!!
« Reply #1 on: April 19, 2011, 08:21:05 PM »
I asked that question a few years back and the answer I got was
nothing. Hope some one chimes in and has a suggestion.
olf20 / Bob
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
Re: Home switches!!
« Reply #2 on: April 19, 2011, 08:41:48 PM »
Do you want it to back farther away from the switch after homing?
If so, change the Ref All script to something like this. This will move the Y 1 unit off the switch.
DoButton( 24 )
DoButton( 23 )
Code "G53 G0 Y1"
While IsMoving()
Wend
DoButton(22)
Offline olf20
  •  325 325
Re: Home switches!!
« Reply #3 on: April 20, 2011, 05:54:08 AM »
Thanks Gerry
I knew someone had done this.
olf20 / Bob
Re: Home switches!!
« Reply #4 on: April 20, 2011, 06:49:40 AM »
Thanks Sir!!!
I will try it!!!!
Re: Home switches!!
« Reply #5 on: April 20, 2011, 04:11:04 PM »
Is there a reason you want to do this?
Offline olf20
  •  325 325
Re: Home switches!!
« Reply #6 on: April 20, 2011, 05:50:41 PM »
As for me, I have a BP clone and do wood working on it. I want to home the machine,
especially X and have it move off the switch so I have some wiggle room to change
bits etc. Y & Z are no problem for me.
olf20 / Bob
Re: Home switches!!
« Reply #7 on: April 20, 2011, 06:12:18 PM »
I see, just wondered :)
