Mach Discussion => General Mach Discussion => Topic started by: jerry74 on April 19, 2011, 07:24:32 PM
Hi to all, i got a question!!
All my home switches are working fine and when i hit Ref ALL HOME works fine also, but what i can do to move the y axis littlebit more far from the home sw when the REF ALL HOME is in process in that axis!
Thanks!!
I asked that question a few years back and the answer I got was
nothing. Hope some one chimes in and has a suggestion.
olf20 / Bob
Do you want it to back farther away from the switch after homing?
If so, change the Ref All script to something like this. This will move the Y 1 unit off the switch.
DoButton( 24 )
DoButton( 23 )
Code "G53 G0 Y1"
While IsMoving()
Wend
DoButton(22)
Thanks Gerry
I knew someone had done this.
olf20 / Bob
Thanks Sir!!!
I will try it!!!!
Is there a reason you want to do this?
As for me, I have a BP clone and do wood working on it. I want to home the machine,
especially X and have it move off the switch so I have some wiggle room to change
bits etc. Y & Z are no problem for me.
olf20 / Bob
I see, just wondered :)
