Hello Guest it is November 13, 2026, 05:54:35 PM
Author Topic: New Pokeys 56 Modbus config with MACH  (Read 34692 times)
Offline borisz
  •  220 220
    • www.poscope.com
Re: New Pokeys 56 Modbus config with MACH
« Reply #10 on: April 30, 2011, 02:36:34 AM »
Hi!
In the next week new software and firmware will be avaiable which will fix that.
regards
Boris
« Reply #11 on: May 12, 2011, 01:09:57 AM »
Ok, new firmware installed, LEDs work OK. Has anyone done jogging in MACH3 with the PK? When I push a button it starts moving and it doesn't stop. I am sure this is something simple.
« Reply #12 on: May 15, 2011, 05:06:48 PM »
I figured it out. I take a signal from the modbus and make it "jog X - right" for example. Then I take the same signal, invert it and terminate it with a "JOG Off X" button.
So more or less I have done everything I need, it's time to put all the switches and pots in some enclosure and test it real world cutting.
