Hello
Guest
it is
November 10, 2026, 01:21:09 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
NPT Thread milling
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: NPT Thread milling (Read 11902 times)
Riley
43
NPT Thread milling
on:
April 13, 2011, 09:40:44 PM »
OK....So how do I go about thread milling NPT? I did find a macro but it didn't run correctly, but I am new to this, could have been me. Have used the thread milling wizard with great results but have the need to run NPT threads quite often.
Logged
Carnoustie, Scotland
Re: NPT Thread milling
Reply #1 on:
April 14, 2011, 02:18:24 AM »
dont think the wizards can handle tapered threads so your best option would be CAM.
Logged
Speedtwin69
19
Reply #2 on:
April 14, 2011, 07:53:09 PM »
The wizard will work if you have a NPT thread mill.
Logged
Proper Planning Prevents Piss Poor Perfomance
Riley
43
Reply #3 on:
April 14, 2011, 08:24:00 PM »
Thats a good point.....I will check into that.
Logged
BR549
6,965
Reply #4 on:
April 14, 2011, 08:34:25 PM »
IF you look on the manf sites for thread mills most have a wizard that can produce the threadmill code for both single point and multi point setups.
Also I think there is a programable macro in the mach tool box section for TMilling npt threads inside and outside.
Also I believe SheetCam has a threadmill modual as well, not sure if it does npt
Last Edit: April 14, 2011, 08:38:18 PM by BR549
Logged
Print
Pages:
1
Go Up
« previous
next »
