Hello Guest it is November 01, 2026, 10:06:58 AM
Author Topic: Need a little help  (Read 25151 times)
Offline rdean
  •  94 94
Need a little help
« on: April 10, 2011, 12:05:30 PM »
Just started using LazyCam and have a question.
I import a wmf file, set the size, input my tool information. set the Z axis, optimize the image, and send to Gcode.
The image turns out just fine and Mach3 does a good job of cutting the piece with one exception.  When ever there is a move to a new starting location the code looks like this:
N35 G1  X1.4378  Y2.3400  Z-0.0250  F6.00
This causes the X Y Z all to move at the same time.
How do I get it to post the code like this with Z moving first and then X Y?
N34 Z-0.0250 F6
I am sure it is something I am doing wrong or have set wrong in LazyCam.
Any help please.
Ray
andrewm
Re: Need a little help
« Reply #1 on: April 11, 2011, 03:27:08 PM »
Im not to familiar with lazycam but you could look for a save z option in the settings, or, try using the safe z setting in mach.
« Reply #2 on: April 11, 2011, 04:18:21 PM »
Ray,
Post the LCam file for what your doing.
Offline rdean
  •  94 94
« Reply #3 on: April 11, 2011, 09:21:13 PM »
Sorry it took so long to get back to you.
I attached both the lcam and the tap files.
Ray
