Hello Guest it is November 01, 2026, 11:51:12 AM
Author Topic: IMPORTING PLT-DXF  (Read 19411 times)
IMPORTING PLT-DXF
« on: November 25, 2006, 04:35:49 PM »
HELLO
 I AM NEW I THIS GROUP AND I LIVE IN TE NETHERLANDS I MAKE STEAMMODELS FOR A HOBBY AND RECENTLY I BUILT MY FIRST CNC ROUTER SO SORRY FOR MY ENGLISH.
I WANT TO ASK YOU CAN LAZY CAM WORKS IN MM ?
WHEN I IMPORT A PLT ORE DXF FILE DRAWN IN MM THAN IT IS IN LAZY CAM IN INCHES ALSO IN MACH AFTER IT HAS GENERATED THE G CODE
I DOWNLOADED THE LATEST MACH 3 NR2 VERSION
SO AM I DOING SOMETHING WRONG OR IS IT NOT POSSIBLE ?
BEST REGARDS PIET
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: IMPORTING PLT-DXF
« Reply #1 on: November 25, 2006, 06:00:31 PM »
Hi, Piet
As far as I now, LazyCam and Mach3, work in UNITS,  MM or Inch.
Check your Mach3 is not in Inch. Mode.
In Mach3, goto Config, Select Native Unit's, OK, Set Default Units to MM, then OK.
If it was in Inch mode you will need to adjust your Step's Per settings in Motor Tuning if there setup
Hope this Fixes your Problem.
Thanks, Chip
« Reply #2 on: November 25, 2006, 06:38:59 PM »
[img]thanks for your reply in Mach3 everything is oke and set in mm.
the problem is wen i import a file that a made in corel draw ore autocad in mm ,in lazycam after importing the x-y stock size is in inch
so when i draw a squire of 1oo mm after importing in lazycam the x-y values are then 3.9350
so 3.9350x25.4=100 mm   note 1 inch =25.4mm
i hope you can help me?
Offline Chip
  •  2,055 2,055
« Reply #3 on: November 25, 2006, 07:39:54 PM »
Hi, Piet
Have you issued a G21 on the MID input line, or put a G21 the top of your G-code file.
Maybe your in G20 Inch mode.
Would you post the DXF files, I'd like to look at them.
Thanks, Chip
« Last Edit: November 25, 2006, 08:54:18 PM by afn09556 »
« Reply #4 on: November 26, 2006, 04:42:46 AM »
HERE IS THE FILE I HOPE THAT HELPS
GREETING PIET
« Reply #5 on: November 26, 2006, 06:08:05 AM »
Hello Piet,
I loaded your DXF in a CAD programm and it turn's out it's already in Inches.
The problem lies in your CAD programm and not in Lazycam our Mach3.
Kind regards from the Netherlands to
Piet
« Reply #6 on: November 26, 2006, 07:50:19 AM »
Try this. 100 x 100 drawn in AutoCAD 2006.
« Reply #7 on: November 27, 2006, 03:22:05 PM »
hello chip
i am happy :) that you found the problem i made the drawings in coreldraw 8 and i learned now that the program export a dxf ore plt file always in inch measurements.
i did some research work and i now know that coreldraw 12 has a function to export in mm ore inches also the line thickness is ignored so a need that version
now i know that Mach/lazycam  also woks in mm i will order a copy off the Mach this week i will thank you for your help and our patients
greetings piet
Offline Chip
  •  2,055 2,055
« Reply #8 on: November 27, 2006, 07:20:40 PM »
Hi, Piet
Everyone helps out, around hear, its great.!!
Thanks, Chip
