Hello Guest it is October 24, 2026, 01:55:20 PM
Author Topic: 3 Parallel Port cards??  (Read 22203 times)
« on: April 10, 2011, 10:05:07 AM »
Is there a limit as to how many parallel port cards can be used with Mach3??
 I am currently running 2 in the machine I am building. the first card is pretty much used up controlling the TB6550 controller board. it seems to require Step, Dir & enable pins for all 3 axis plus spindle control and there are no pins left.
 I added a second card to control some Solid state relays for Vacuum and flood pump and I am using the rest of the pins for manual direction control.
 But I would like to add a 3rd card so I can utilize the P.I.D function for spindle speed control. I just don't have anymore available inputs on the 2 existing cards.
 So I'm curious if I can run 3 cards with Mach3. assuming I can get 3 cards to run in the PC in the first place.
Re: 3 Parallel Port cards??
« Reply #1 on: April 10, 2011, 10:43:32 AM »
Two parallel ports is the max as far as I am aware.
« Reply #2 on: April 10, 2011, 10:59:58 AM »
that's a bummer with only 10 input pins. I need one more! or i need to re-think how to do the jog buttons.
I currently have:
X Limit
Y Limit
Z Limit
E stop
Jog X+
Jog X-
Jog Y+
Jog Y-
Jog Z+
Jog Z-
 and that wipes out all 10 pins. I need a way to get a speed pulse into Mach3 any suggestions??
 I suppose I could disassemble a USB keyboard, remove the keyboard PCB and wire the arrow keys to the direction buttons on the panel. that would free up 6 input pins. but i really don't want to do that if i don't have to.
 Plus I would like to be able to add a digitizer at some point and that will require yet more pins....hmmm
« Reply #3 on: April 10, 2011, 11:52:35 AM »
you could wire the x, y, and z limit switches in series and run them into one input, which will give you two inputs free.
« Reply #4 on: April 10, 2011, 11:54:26 AM »
I was wondering if i could do that or if there was a reason it needed all 3?? sweet well there are the 2 pins i need then!
« Reply #5 on: April 10, 2011, 12:58:31 PM »
Other thing to look at is something like the PoKeys, it will give you approx 55 I/O if I remember right. Time critical things such as home switches and step/dir will need to be on the port but things like external switches the Pokeys will handle very well.
« Reply #6 on: April 11, 2011, 07:27:31 AM »
You can probably use a jumper to enable your drives, and not have to use the paralel port, which free up 3 pins. Are you using a breakout board that allows pins 2-9 as inputs on the second port? That may help.
« Reply #7 on: April 11, 2011, 06:05:26 PM »
I have 2x 25 pin breakout boards in my custom motor controller box. I have access to all 25 pins on the BOB, there is a cable that connects from the BOB to the circuit board. so yes I have access to all pins. So can i jumper the enable lines to +5v? or should I jumper the three axis together to one PC port enable pin?
 I am using a HY-TB4DV-M Toshiba TB6560 motor controller board commonly found on eBay.
  •  9,374 9,374
« Reply #8 on: April 12, 2011, 06:33:57 AM »
If its any help I have taken all enable lines through toggle switches (mounted on the controller case) to +5 volts  and this allows an axis to be disconnected if required for any purpose.
« Reply #9 on: April 12, 2011, 06:39:34 AM »
sweet. ok I am reworking how I am going to do this then. Thanks!
