Hello Guest it is November 13, 2026, 06:17:48 PM
Author Topic: Can I add an enable and disable function in the macropump  (Read 10894 times)
« on: April 06, 2011, 11:05:08 PM »
Would like to add this function to the macropump.
I have a switch on the pendant to put it on or off.
But if I leave it off, feed rate and spindle override are set to approx. zero.
If I turn it on, DRO's are set to the value on analog inputs.
Would like to add a switch to enable or disable the pendant in so I can use the mouse if I want.
Thanks, Jeff
Re: Can I add an enable and disable function in the macropump
« Reply #1 on: April 27, 2011, 08:12:24 PM »
You set up your switch . Inside the Macropump at the start of the code check the value of a led that is turned on /off with the switch.
If the led is on then continue with the rest of the code . IF the LED is off then jump to the end and bypass the pendant code
Just a thought, (;-) TP
