Hello Guest it is October 20, 2026, 03:08:51 PM
Author Topic: Setting Feed Rate  (Read 9908 times)
Offline cdis
  •  11 11
Setting Feed Rate
« on: April 06, 2011, 09:21:24 PM »
My feed rate is set at 1.00.  I try to change it to 75.00 but it will reset to 1.00.  I have tried to change it both on the "program run" and the "MDI"  Hope you can help.  SOrry for being such a novice.  Neil :P
Re: Setting Feed Rate
« Reply #1 on: April 06, 2011, 10:59:58 PM »
Is it possible the velocity is set to one in the motor tuning.
Is it the same for all axes.
Jeff
« Reply #2 on: April 07, 2011, 06:27:05 AM »
There's probably an F1 in your g-code.
Offline cdis
  •  11 11
« Reply #3 on: April 07, 2011, 07:34:05 PM »
I will check that
Thank you
