Hello Guest it is November 13, 2026, 09:39:09 AM
Author Topic: taig mill  (Read 32725 times)
Offline nige
  •  23 23
  • feel the force
taig mill
« on: November 25, 2006, 06:13:44 AM »
hello folks
complete newbee to the forum
i have been running a taig mill for two years on the mps2003 programme and have been a little downhearted with the lack of control
not that I'm an experienced engineer, quite the opposite  i am a designer and relatively new to engineering.
we are a UK based company and  have been using artcam software to create jewellery which is a fantastic programme and the taig mill is adequate for our use as most of the stuff we produce is wax so we are not really dealing with torque so much, we also use mills from bits and bits in the US.
when i saw the Mach 3 programme i thought i should give it a whirl ,however it seems a little complex so Ive got my head down in the pdf manual so i might be some time ....................
my question is if anybody is or has used taig mills with Mach 3 and if so could i be setting the pins wrong or something ??? as i cant seem to get any com/ control
i would appreciate any feedback at all
Re: taig mill
« Reply #1 on: November 25, 2006, 06:25:28 AM »
I suggest also you download the videos as they will give you a quick understanding of how to set up Mach. Once you are set up then referring to the manual for specifics will be a great help. If you need help then this forum should be able to help with more specific questions.
Offline nige
  •  23 23
  • feel the force
Re: taig mill
« Reply #2 on: November 25, 2006, 06:35:55 AM »
thanks hood im watchin the vids
would like to purchase but need to know a bit more
ciao f now
Re: taig mill
« Reply #3 on: November 25, 2006, 06:44:41 AM »
Where in UK you from?
Offline nige
  •  23 23
  • feel the force
Re: taig mill
« Reply #4 on: November 25, 2006, 06:45:49 AM »
southport merseyside
we are the jewellery workshop
Re: taig mill
« Reply #5 on: November 25, 2006, 06:53:27 AM »
I am up in Scotland, there are quite a few guys here from the UK.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: taig mill
« Reply #6 on: November 25, 2006, 07:48:01 AM »
Im in West Yorkshire.
Graham.
Offline nige
  •  23 23
  • feel the force
Re: taig mill
« Reply #7 on: November 25, 2006, 09:23:53 AM »
hi guys
ive got  a million buttons before my eyes and no output
i get control from the jog in the software but no motion on the machine
the handshake is ok in the bios so im not sure if the output is right
i have g code loaded and simulation is running ok ???? does anybody have a taig 200o hooked up to mach3 ?
Re: taig mill
« Reply #8 on: November 25, 2006, 09:42:21 AM »
Where are you losing the signal? Do you have any enables on the control side that are not made? Can you post some screen shots of your settings? Are you using a straight through 25 pin cable? Not a printer cable. Did you install drivers when you downloaded mach?
Offline nige
  •  23 23
  • feel the force
Re: taig mill on the launch pad x2
« Reply #9 on: November 25, 2006, 10:40:15 AM »
here are the screen shots
sorry im not to clear about it all
im checking out at five  so ill catch ya  later thanks for the encouragement
HARRY @ NIGES
« Last Edit: November 25, 2006, 10:41:50 AM by nige »
