Hello Guest it is October 20, 2026, 07:03:32 PM
Author Topic: Need a Tool path to level our Table  (Read 20947 times)
Re: Need a Tool path to level our Table
« Reply #10 on: April 07, 2011, 06:27:34 PM »
Cant see how that would be unless your keyboard wasnt working. Only  other thing I can think of is you have the Auto Calculator enabled and you wil need to use your mouse to enter the values via the calculator that pops up.
Offline cdis
  •  11 11
« Reply #11 on: April 07, 2011, 07:11:01 PM »
Thanks I will try again tomorrw.  Could you please see my post on feed rate and give me an answer on that?  Is so thank you.
« Reply #12 on: April 07, 2011, 08:21:43 PM »
If using the Number keypad, do you have Num Lock on ?
Did you try thr row of numbers above the letters on the keyboard ?
Good luck,
Russ
