Hello Guest it is November 24, 2026, 08:45:19 PM
Author Topic: DXF Symbol for drill? Anyone... Anyone???  (Read 11408 times)
Offline sn96
  •  60 60
« on: March 28, 2011, 08:16:52 PM »
Hello Guys,
Been breaking my self in to this new hobby, literally! I broke another endmill. I need to think twice and cut once. Anyway, does anyone know if you can use a drawing symbol that mach3 would interpret as a drill point?
Mike
Mike
________________________________
PM25mv with Arizona cnc conversion kit
windows 10
i7 laptop
mach3 demo latest version
stepperonline 566 ozin closed loop stepper 4.0 driver for x and y
stepperonline 1699 ozin closed loop stepper 4.0 driver for the z
amazon no name brand usb controller
Re: DXF Symbol for drill? Anyone... Anyone???
« Reply #1 on: March 29, 2011, 04:11:29 AM »
Mike,
Not sure what you are trying to do. If you are using LazyCam and want to define what points are to be drilled you can just draw a circle where the drilled holes are in CAD.
See page 41 in the manual.
Offline sn96
  •  60 60
« Reply #2 on: March 29, 2011, 06:40:45 PM »
Sorry for such a long delay, I am up to my eyeballs with work... at my work.
Hello Rich, sorry I didn't provide more details on what I was doing. I was importing dxf drawings using an older version of mach3 that has the import feature. The dxf files I import treat circles as circles which is fine but I was wondering if there was a symbol with crossing lines like + or X that would be interpreted as a centroid. I was able to edit the G-code and change G2 to G83, but I ended up changing some circles to drill by accident. If I can use a symbol then importing a dxf would be a little easier.
I am only playing around for the time being.  I am saving up for Visual Mill which will make a lot of things possible, but I was experimenting with cutting simple parts and the old mach3 dxf was a great starting point and I have cut several shapes so far using this utility.
Mike
« Last Edit: March 29, 2011, 06:42:39 PM by sn96 »
Mike
windows 10
i7 laptop
« Reply #3 on: March 29, 2011, 06:44:04 PM »
Mike,
Not to my knowledge and don't use or know anything about the old version of Mach.
« Reply #4 on: March 30, 2011, 11:45:46 AM »
Most CAms use a standard point to represent a drill point. Just insert a point where you want the hole.
