Hello Guest it is October 20, 2026, 03:53:41 PM
Author Topic: help please  (Read 21527 times)
  •  9,374 9,374
Re: help please
« Reply #10 on: March 29, 2011, 02:50:09 AM »
Could be.
Look to see if 'Safe Z' under the config tab is enabled.
Re: help please
« Reply #11 on: March 29, 2011, 11:05:06 PM »
sorry is not z axis :-[ is Y axis
  •  9,374 9,374
Re: help please
« Reply #12 on: March 30, 2011, 01:25:01 AM »
OK, assuming you are getting to the last line of your GCode (M30) when it is run then my opinion is that the problem is within your controller rather than Mach or your setup. The M30 should terminate any pulses from Mach so what could be driving your Y axis ?
