Hello
Guest
it is
October 24, 2026, 11:43:23 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Spindle
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Spindle (Read 35986 times)
Carnoustie, Scotland
Re: Spindle
Reply #10 on:
March 22, 2011, 02:40:44 PM »
From the description it sounds like the relay is meant for switching a VFD's Fwd/Rev. I will presume the Gnd is actually the common terminal . The V+ may be the relays Normally closed contact and the V- may be the normally open.
Do you have a multimeter that you could test continuity of the relay contacts with?
jr_82
29
Re: Spindle
Reply #11 on:
March 22, 2011, 02:51:52 PM »
I have tried that but, I do not know if it is actually on or not, I never get anything over 4v. I can hear it click on and off, but I have no Idea if I even have the correct pins going where they need to. I only know that pin 9 is for the spindle.
Junior
andrewm
Re: Spindle
Reply #12 on:
March 22, 2011, 02:57:25 PM »
This is the manual for your board.
http://www.cncgeeker.com/images/manual/CNC/3axisTB6560cncdriveCNCGeeker.pdf
Last Edit: March 22, 2011, 03:07:40 PM by AndrewM
Re: Spindle
Reply #13 on:
March 22, 2011, 03:00:42 PM »
Ok set Mach up as I mentioned but dont connect the motors power wires to anything. Take your meter and put it into a low Ohm range or buzzer if it has one. Connect one probe to the Gnd and touch the other to the V+ and see if it has continuity. If it does then go to the V- terminal and it should not have continuity. Next start the spindle in Mach and you should now get the continuity on the opposite terminal and no ontinuity on the one that previously had it.
jr_82
29
Re: Spindle
Reply #14 on:
March 22, 2011, 03:05:39 PM »
http://lz4gv.my.contact.bg/CNC_files/3Axis_Driver_txt.pdf
Here is the link, it is the closet thing I have, Looks identical and pins are the same.
Junior
jr_82
29
Re: Spindle
Reply #15 on:
March 22, 2011, 03:12:16 PM »
no nothing is hapening, just says 0.L no matter what I do. Do I have to turn anything on? do I have to turn on the spindle output. You will have to be very specific, I have no Idea what I am doing.
Junior
jr_82
29
Re: Spindle
Reply #16 on:
March 22, 2011, 03:22:14 PM »
Signal Output enabled port 1 Pin 9 Do I need to turn on the spindle in the motor settings? if so What step pin and dir pin. Under spindle settings. Use spindle ouputs? It clicks when I turn the spindle on, and off, nothing else happens. No volts no beeps nothing.
Junior
Re: Spindle
Reply #17 on:
March 22, 2011, 03:25:44 PM »
Ok if it is clicking as you turn spindle off and on then relay is working. You will not get a voltage but if you have your meter on buzzer you should hear a beep when the contacts close. I am not sure which pins are which but you neet one probe of the meter to the relay common which I presume is called Gnd and the other to the V+. Switch the spindle on and off and you should hear a beep either when on or when off. If you dont then take the probe from the common (Gnd) and connect it to V- and try switching the spindle on/off button again.
jr_82
29
Re: Spindle
Reply #18 on:
March 22, 2011, 03:31:34 PM »
OK it beeps when I do that V+ to V- and turns back off.
Junior
jr_82
29
Re: Spindle
Reply #19 on:
March 22, 2011, 03:33:59 PM »
So is it just a relay? Or should it put out voltage to the motor? It puts out voltage to the stepper motors. xyz. axis.
Junior
Print
Pages:
1
2
3
Go Up
« previous
next »
