Hello Guest it is September 14, 2026, 06:21:47 AM
Author Topic: Shift Key  (Read 48213 times)
LeeDove
Shift Key
« on: January 25, 2006, 06:28:00 AM »
I have just got a nifty wireless keypad which allows me to use it as a pendant for manual axis control. The only problem is that it does not have a SHIFT key. Does anyone know how I can reassign the Shift in Mach 3 or remap rapid travel to not need the shift key.
Lee Dove
Re: Shift Key
« Reply #1 on: January 25, 2006, 11:04:03 AM »
There is an OEM code that will do it I think... I will get back to you on that.
www.newfangledsolutions.com
www.machsupport.com
Re: Shift Key
« Reply #2 on: January 25, 2006, 03:02:48 PM »
No such luck :( So we are going to have to add a littl VB code to make your keyboard work :) We can have a button on the screen to set you to 100% jog and we will write the old slow jog rate to a Var in Mach3. So it will be about the same as having a shift key .... Is this okay?
www.machsupport.com
LeeDove
Re: Shift Key
« Reply #3 on: January 27, 2006, 04:10:36 AM »
Sounds fine to me. So in effect you will create a key similar to Caps Lock whic I can assign.
Lee
Re: Shift Key
« Reply #4 on: January 28, 2006, 05:16:54 PM »
Yes:)
www.machsupport.com
LeeDove
Re: Shift Key
« Reply #5 on: February 20, 2006, 07:58:32 AM »
Was your suggetion to help me write the code or are you intending to do it ?  ;D
Re: Shift Key
« Reply #6 on: February 20, 2006, 10:11:12 AM »
You give me the scrren set that you are going to be running and I will add in the code
www.machsupport.com
LeeDove
Re: Shift Key
« Reply #7 on: February 20, 2006, 11:03:07 AM »
I use the default screens that come with Mach 3. I suppose I would need to use it on the mdi screen and when setting up using offsets.
Re: Shift Key
« Reply #8 on: February 20, 2006, 10:34:31 PM »
okay I will have a look tomorrow
www.machsupport.com
LeeDove
Re: Shift Key
« Reply #9 on: March 08, 2006, 11:07:10 AM »
Any movement on this yet a :-)
