Hello Guest it is November 13, 2026, 06:09:28 AM
Author Topic: DRIVER TEST: Compatibility problem  (Read 10036 times)
Offline asa
  •  2 2
« on: March 17, 2011, 08:56:38 PM »
hello,
when i run driver test, continous(merged) bars are displayed, tried to set pc to "standard pc" but i m not able to, it doesnt reboots.
tried installing fresh OS with this setting but its not getting installed.
what should i do?
Re: DRIVER TEST: Compatibility problem
« Reply #1 on: March 18, 2011, 02:18:53 AM »
If you have installed a fresh copy of the OS and trie the steps outl;ined in the optomisation document then a PCI parallel port may work, if not you will have to try another computer.
« Reply #2 on: March 18, 2011, 05:55:32 PM »
You need to set standard PC in the bios, then re-install windows.
Offline asa
  •  2 2
« Reply #3 on: March 18, 2011, 05:59:08 PM »
how to set BIOS?
