Hello
Guest
it is
November 13, 2026, 06:09:26 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
DRIVER TEST: Compatibility problem
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: DRIVER TEST: Compatibility problem (Read 10035 times)
asa
2
on:
March 17, 2011, 08:56:38 PM »
hello,
when i run driver test, continous(merged) bars are displayed, tried to set pc to "standard pc" but i m not able to, it doesnt reboots.
tried installing fresh OS with this setting but its not getting installed.
what should i do?
Logged
Carnoustie, Scotland
Re: DRIVER TEST: Compatibility problem
Reply #1 on:
March 18, 2011, 02:18:53 AM »
If you have installed a fresh copy of the OS and trie the steps outl;ined in the optomisation document then a PCI parallel port may work, if not you will have to try another computer.
Logged
ger21
6,295
Reply #2 on:
March 18, 2011, 05:55:32 PM »
You need to set standard PC in the bios, then re-install windows.
Logged
asa
2
Reply #3 on:
March 18, 2011, 05:59:08 PM »
how to set BIOS?
Logged
Print
Pages:
1
Go Up
« previous
next »
