Hello
Guest
it is
November 13, 2026, 11:25:51 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Backlash ON problem Y axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Backlash ON problem Y axis (Read 9227 times)
Pupak
on:
November 22, 2006, 12:24:18 PM »
If Backlash ON and Axis Y move to more cca 15mm,speed for Y is not OK -> crash (lost steps). Tested on Mach2 and Mach3 - 2.00.12 on different computer and machines.
Logged
Brian Barker
3,860
Re: Backlash ON problem Y axis
Reply #1 on:
November 24, 2006, 12:16:11 PM »
What do you have the backlash % speed correction set to? try setting it down to about 10% and see if you still have the problem
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
