Hello Guest it is November 13, 2026, 10:15:27 AM
Author Topic: can not do zero repeats  (Read 14964 times)
« on: November 22, 2006, 11:59:24 AM »
I just tried to run this drilling file and got that error. Any ideas on whats wrong?
G00 G49 G40.1 G17 G80 G50 G90 G20
(Standard Drill )
T0 M6
G43 H0
M03 S2000
G00 Z0.0312 X-0.8688 Y0.0000
G81 X-0.8688 Y0.0000 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X-0.7828 Y0.3769 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X-0.5418 Y0.6791 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X-0.1935 Y0.8468 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X0.1930 Y0.8468 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X0.5413 Y0.6791 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X0.7823 Y0.3769 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X0.8683 Y0.0000 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X0.7823 Y-0.3769 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X0.5413 Y-0.6791 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X0.1930 Y-0.8468 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X-0.1935 Y-0.8468 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X-0.5418 Y-0.6791 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
G81 X-0.7828 Y-0.3769 Z-0.235 R0.1 L0.0
G80
G00 Z0.0312
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: can not do zero repeats
« Reply #1 on: November 23, 2006, 02:14:19 AM »
Remove the 'L0.0' from each line and replace them with a feed rate (F1.0), then try again
Graham.
« Last Edit: November 23, 2006, 02:16:48 AM by Graham Waterworth »
zaki
« Reply #2 on: November 27, 2006, 06:12:00 AM »
normally L and K is denoted for repeatations. If u put L1 its make sense to run the G81 or any canned cycle one time, if u put 2 its run 2 times and if u put 0 its take the position for hole but not run the cycle. we put this in Fanuc if we skip some holes.
« Reply #3 on: November 27, 2006, 08:59:01 AM »
Yup I have done that on a fanuc too... Don't know if we can get that to work in Mach3
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
  •  2,785 2,785
« Reply #4 on: November 27, 2006, 11:39:59 AM »
I see what you are saying but in the code above it would not drill a single hole, so why bother writing the code in the first place.
Not only that its very inefficient code. I could be done in a third of the lines.
It reminds me of Microshaft, why do in 20 lines, what you can do in 200
Graham.
« Last Edit: November 27, 2006, 11:45:35 AM by Graham Waterworth »
  •  2,785 2,785
« Reply #5 on: November 27, 2006, 11:54:06 AM »
This would do the same job, except it would actually drill holes
(Standard Drill )
T0 M6
G43 H0
M03 S2000
G81 Z-0.235 R0.1 F1.
X-0.7828 Y0.3769
X-0.5418 Y0.6791
X-0.1935 Y0.8468
X0.1930 Y0.8468
X0.5413 Y0.6791
X0.7823 Y0.3769
X0.8683 Y0.0000
X0.7823 Y-0.3769
X0.5413 Y-0.6791
X0.1930 Y-0.8468
X-0.1935 Y-0.8468
X-0.5418 Y-0.6791
X-0.7828 Y-0.3769
G80
