Hello
Guest
it is
October 10, 2026, 09:18:39 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
mach 3 and vista
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: mach 3 and vista (Read 18044 times)
compositepro
10
mach 3 and vista
on:
November 22, 2006, 11:24:16 AM »
seems to work
Chaoticone
5,624
Precision Chaos
Re: mach 3 and vista
Reply #1 on:
November 22, 2006, 11:38:38 AM »
Are you saying that you are running Mach on a PC with Vista OS and all is well?
If you could see the things I have in my head, you would be laughing too.
Yodawill2000
Reply #2 on:
November 22, 2006, 11:40:47 AM »
Do tell !!!
Ive played with the demo at work and MAN does it look sweet.
Vista that izz.
compositepro
10
Reply #3 on:
November 22, 2006, 01:51:13 PM »
yep build 6000 which is vista final release available early on MSDN
only problem i had was a dll which would'nt register due to microsofts funky new file protection system but once that was taken care of all runs fine
however having used vista from beta onwards i will tell you stick with xp Vistas just anew toy its not really geared towards us cnc typesand tobe honest im growing tired of fighting with it whenever i want to install a program
btw anyone know if theres a post for edgecam
ART
1,703
Tough as soggy paper.
Reply #4 on:
November 22, 2006, 02:47:50 PM »
Hi:
I think you may be fooling yourself. The driver doesnt load properlyunder all Vista builds Ive seen. If you check the Diags page you will see it says either simulate, or 25000 exaclty , which means its in sim mode. (Now if you can run the drivertest.exe successfully, Id LOVE to hear that!
Art
compositepro
10
Reply #5 on:
November 22, 2006, 03:20:52 PM »
correct art my fault
it runs ok as sim though
should'nt be too much of a problem to fix eh??
ART
1,703
Reply #6 on:
November 22, 2006, 03:30:58 PM »
Darn, you had my hopes up.
, thankis for trying though, tghe experiment is always worthwhile.
When Vista is fully released, Ill likely try taking a run at it, but XP was a miracle, so I wouldnt count on it..
Art
compositepro
10
Reply #7 on:
November 22, 2006, 04:13:29 PM »
hey art it install ok
on the rc2release ihad a dll the wouldnt install at all
i understand theres some issue about about how it controls the xp process well windowsvista lets you run in xp compatibility mode so maybe
in fact back soon when ive tried that
compositepro
10
Reply #8 on:
November 22, 2006, 04:26:43 PM »
ok art reinstall under windows xp sp2 compatibility mode runs then just hangs so reboot in order
then
LOW AND BEHOLD
SYSTEM UNDER MACH 3 CONTROL
pulses 24069- 24093
cpu speed1894
apic timing 4142
mach test complete
OK
whats dinput8dll
Print
Pages:
1
Go Up
« previous
next »
