Hello Guest it is November 13, 2026, 11:04:39 AM
Author Topic: Want to convert my Bridgeport series one into new cnc  (Read 32404 times)
zaki
« on: November 22, 2006, 02:00:25 AM »
Hi Guys
I have a cnc mill Bridgeport Series 1, the controller is dameged during traveling. Can I convert that machine into CNC again by this Artsoft??
Re: Want to convert my Bridgeport series one into new cnc
« Reply #1 on: November 22, 2006, 02:21:02 AM »
I have done it, see here http://mysite.wanadoo-members.co.uk/hoodsmachiningpages/Series1Retro.htm
What version of mill do you have, mine was a BOSS 6.1, does yours have servos or steppers?
zaki
« Reply #2 on: November 22, 2006, 03:22:31 AM »
Actually I have both machines here. I Just want to know what will I need to make machine 100% ready? Can I install it by my self? or it needs some expert personell? Is it runs on just G codes? what kind of pc I will need?
« Reply #3 on: November 22, 2006, 04:15:19 AM »
Hi
I've also convert my Bridgeport Series 1 Boss 6.1 with steppers, I used all the original drivers and motors, just changed the control.
There is quite a few people done this, have a shearch on CNCzone you'll find quite a few threads about doing it like this one http://www.cnczone.com/forums/showthread.php?t=24314
You should be able to convert the servo version to but that will be a bit more complicated.
Chris
« Reply #4 on: November 22, 2006, 07:57:17 AM »
Hey,
   You won't need any experts. If you do, they are on here. I have a bare bones Dell Dimension B110. It works great.
zaki
« Reply #5 on: November 25, 2006, 02:45:05 AM »
Hey Chaoticone
thanx dear 4 ur reply, how many serial or parallel ports will I need? by with means computer will connect with motor drives etc???
« Reply #6 on: November 25, 2006, 03:41:41 AM »
You can use one or two ports, I have two in mine but if you just have limits and drives you can get away with only one port.You can use one limit switch per axis and configure it to be a limit for + and - and also it can act as a home switch when doing a reference move, this will save greatly on inputs needed.
zaki
« Reply #7 on: November 25, 2006, 05:19:58 AM »
Bundle of thanx Hood
I am still looking for more replies and views :o
« Reply #8 on: November 25, 2006, 08:17:06 AM »
Another thing I think is neat is an Ipac keystroke emulator. It hooks either to a ps2 connection or a USB port. With the Ipac 4 you can add 56 inputs. You set it up in Keygrabber.
http://www.ultimarc.com/ipac1.html
« Reply #9 on: November 25, 2006, 09:14:47 AM »
Not sure if I remember correctly but I seem to recall that the USB versions didnt work too great in Mach so best sticking to the PS2 versions to be on the safe side, I have one and it is great for adding physical buttons ;)
