Hello Guest it is November 22, 2026, 02:27:03 PM
Author Topic: Spindle speed control when changing direction  (Read 13481 times)
« on: February 28, 2011, 06:09:08 PM »
Looked around and searched the forum...
The spindle motor controller in my machine requires that the motor is stopped before changing direction.
Ideally before changing the spindle direction;
1) Spindle speed is set to 0
2) Wait for the shaft index pulse to read 0 RPM
3) Change the spindle direction
4) Spindle speed back to what it was...
Is there a way to do this with G-Code, or is this something that needs to be done in Mach3?
If in Mach3 any help with that?
Derek Vanditmars
Re: Spindle speed control when changing direction
« Reply #1 on: February 28, 2011, 06:39:20 PM »
I'm not sure if I understand correctly your question.
Normally, M3 will spin motor CW
             M4 will spin motor CCW
             M5 will Stop motor
So  you could use M3 S10000 , M5 to stop spindle and M4 S10000 to reverse it at 10000 RPM CCW.
Jeff
« Reply #2 on: February 28, 2011, 06:49:03 PM »
In the example, between the M5 (stop) and the M4 S10000, (reverse at 10000 RPM).
There would not be enough time for the spindle motor to come to a complete stop, before starting up again.
« Reply #3 on: February 28, 2011, 06:55:16 PM »
I think you could use a delay in the spindle tab configuration
But again, never used it myself.
Jeff
« Last Edit: February 28, 2011, 07:00:05 PM by ostie01 »
« Reply #4 on: March 01, 2011, 08:57:21 AM »
Thanks, Jeff.
I think that will work.
« Reply #5 on: March 01, 2011, 05:48:01 PM »
yOu can also modify the M3/M4 macros to allow the spindle to WAIT for it to stop before continueing.
