G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: DVanditmars on February 28, 2011, 07:09:08 PM
Looked around and searched the forum...
The spindle motor controller in my machine requires that the motor is stopped before changing direction.
Ideally before changing the spindle direction;
1) Spindle speed is set to 0
2) Wait for the shaft index pulse to read 0 RPM
3) Change the spindle direction
4) Spindle speed back to what it was...
Is there a way to do this with G-Code, or is this something that needs to be done in Mach3?
If in Mach3 any help with that?
Derek Vanditmars
I'm not sure if I understand correctly your question.
Normally, M3 will spin motor CW
M4 will spin motor CCW
M5 will Stop motor
So you could use M3 S10000 , M5 to stop spindle and M4 S10000 to reverse it at 10000 RPM CCW.
Jeff
In the example, between the M5 (stop) and the M4 S10000, (reverse at 10000 RPM).
There would not be enough time for the spindle motor to come to a complete stop, before starting up again.
I think you could use a delay in the spindle tab configuration
But again, never used it myself.
Jeff
Thanks, Jeff.
I think that will work.
yOu can also modify the M3/M4 macros to allow the spindle to WAIT for it to stop before continueing.
