Hello
Guest
it is
October 20, 2026, 10:26:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
go to zero jog rate
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: go to zero jog rate (Read 10473 times)
steppmjk
6
go to zero jog rate
on:
February 26, 2011, 08:36:44 AM »
I've set my motor tuning velocities to the max that I can move without skipping.When I click the goto zero button,all axis' go above my set velocities causing them to skip.
How do I set the max velocity for the goto zero button?
ger21
6,295
Re: go to zero jog rate
Reply #1 on:
February 26, 2011, 08:39:53 AM »
The blended velocity is higher, but the individual axis can not exceed the motor tuning velocities.
Does it do the same thing if you use MDI and do a
G0 X0 Y0 Z0
steppmjk
6
Reply #2 on:
February 26, 2011, 08:46:03 AM »
Not sure what you mean I'm new at this. I have noticed that the speed will go higher than my max if I dont slow the speed per minute rates in the cam program
Print
Pages:
1
Go Up
« previous
next »
