Hello Guest it is October 20, 2026, 11:40:29 PM
Author Topic: go to zero jog rate  (Read 10475 times)
go to zero jog rate
« on: February 26, 2011, 08:36:44 AM »
I've set my motor tuning velocities to the max that I can move without skipping.When I click the goto zero button,all axis' go above my set velocities causing them to skip.
How do I set the max velocity for the goto zero button?
Re: go to zero jog rate
« Reply #1 on: February 26, 2011, 08:39:53 AM »
The blended velocity is higher, but the individual axis can not exceed the motor tuning velocities.
Does it do the same thing if you use MDI and do a
G0 X0 Y0 Z0
« Reply #2 on: February 26, 2011, 08:46:03 AM »
Not sure what you mean I'm new at this. I have noticed that the speed will go higher than my max if I dont slow the speed per minute rates in the cam program
