Hello Guest it is October 25, 2026, 06:56:43 AM
Author Topic: Y AXIS STICKS when you assign hotkey  (Read 10248 times)
« on: February 20, 2011, 10:37:00 PM »
Hello,
 I have finished a new screen set for my 4 axis hotwire cutter.  When I use the mouse to depress the Y++ or Y-- buttons - DROs jog properly and stop when I release mouse button.  My XBox360 controller moves the y axis properly with the default plugin settings.  If I assign a hotkey to the Y axis and depress the key - DRO moves in the correct direction - but does not stop when I let go of key.  If assign hotkeys to the other 3 axis in the same fashion - I get the correct result - push button axis moves - let go of button axis stops.  What am I missing?  Running Licensed Version R3.042.040.
Kris
Re: Y AXIS STICKS when you assign hotkey
« Reply #1 on: February 21, 2011, 02:25:55 AM »
Is this
in the plugin and using the X Box or?
« Reply #2 on: February 21, 2011, 08:02:57 AM »
I assign the hotkey in the screen designer with either a standard Mach button or an image button  - essentially just calling the action from the keyboard.
***  Not to muddy the waters - but when I assign X and A ++ / --  to an image button I get the same result.  If I assign
the X and A ++/-- to a stock Mach button it works fine.
