Hello Guest it is November 13, 2026, 09:48:17 AM
Author Topic: Machine Zero Resetting  (Read 12640 times)
« on: November 19, 2006, 09:36:16 PM »
I am new to CNC and learning a lot.  I have a Taig mill with steppers on  X and Y.  I will add the Z stepper as soon as I get comfortable moving the table around.
I am running Mach3, version R1.84.001, Bob Campbell's Mach3 Enclosure, and Bob's SoundlogicM3.xml  file.  I don't have limit or home switches on the mill yet.
No problem running several simple G Code files, but I found that my machine zeros were changing.  I finally figured out that if I move the table to some location away from X and Y zero, close Mach3, and restart Mach3, machine zero is then at the last spindle location before shutting Mach down.  From listening to Art's Homing and Limits video several times, I thought that machine zero could only be changed by referencing the machine to the home switches and of course, I don't have home switches yet.  Any suggestions.  I may have something set wrong or be doing something wrong.  I am not sure I've given enough information, so please let me know if some other detail is needed.
Chuck
Re: Machine Zero Resetting
« Reply #1 on: November 20, 2006, 06:20:46 AM »
Hey Chuck,
     Do you have persistant offsets enabled?
I can't remember where this is set in version 1.84. Maybe config, mill options. Set your's up like these and see if that does it.
« Last Edit: November 20, 2006, 07:06:07 AM by Chaoticone »
« Reply #2 on: November 20, 2006, 07:06:49 AM »
Put in a better pic.
« Reply #3 on: November 20, 2006, 05:00:18 PM »
Hello Chaoticone,
Thanks for the tip.  I didn't have persistent DROs selected.  Now machine zero stays the same when I power down and come back up.  Also, I now know an easy way to move machine zero.
Chuck
« Reply #4 on: November 20, 2006, 05:03:29 PM »
Good, glad you got it. :)
