Hello Guest it is November 17, 2026, 02:28:14 AM
Author Topic: Homing Trouble  (Read 10872 times)
Homing Trouble
« on: February 20, 2011, 12:15:20 AM »
I am having difficulty with homing.  When "Ref all" is hit the Z homes normally......hitting the switch and backing off.  The Y hits the switch and triggers a "limit switch active" message.  I have all my homing/limit switches wired in series to pin 10 active low.  The Y and X were homing corrctly until I added the switch for the Z axis.  I disable homing on the Y and th X is doing the same thing......hitting the switch and locking up the machine.  I have the auto limitoverride on.  What in the wide world of sports is going wrong?
Re: Homing Trouble
« Reply #1 on: February 20, 2011, 02:06:50 AM »
Try a debounce interval of 2000, if that helps then either your switches are not the best and bouncing or you are needing to shield the wiring properly.
Re: Homing Trouble
« Reply #2 on: February 20, 2011, 07:57:03 AM »
Fixed!  Thank you Hood for the good information.  My machine is now working with a debounce of zero.  I suppose that running the limit switch wiring within the same wire chase and and wire loom as the stepper motors made for a neat installation appearance-wise but was electronically sloppy.
Bob
Re: Homing Trouble
« Reply #3 on: February 20, 2011, 08:08:38 AM »
Yes thats the best way, dont like using debounce myself as it means there is a problem with the wiring and I hate that ;D
