Hello Guest it is November 27, 2026, 10:44:59 AM
Author Topic: Interface Tutorial  (Read 23278 times)
Re: Interface Tutorial
« Reply #10 on: February 15, 2011, 02:12:28 PM »
Ok, forget about Safe Z for now, it's used to clear the part, clamps or other parts of the set up while rapiding and/or going to the tool change pos (among others).
I believe you are correct about the inhibit.
You set the Persistand where Hood mentioned, Ports n pins, spindle setup.
Your # of passes in the wizard is determined by the total depth and the depth per pass selected.
Be back shortly,
Russ
Offline kolias
  •  1,165 1,165
« Reply #11 on: February 15, 2011, 05:32:24 PM »
Thanks Russ, finally I’m there LOL
ok so I got the Z-Inhibit what it does and how we set it on and besides the main Mach screen the Z-Inhibit is also on the Ports & Pins menu / Mill Options and there it’s also the Persistant Option
In other words the Z-Inhibit is a safety option to prevent the Z travelling lower than a certain limit
Thanks for your time
Nicolas
