Hello
Guest
it is
November 04, 2026, 01:00:32 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Differential Signal Converter board DIY freebee G-code included
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Differential Signal Converter board DIY freebee G-code included (Read 7976 times)
simpson36
1,369
on:
February 12, 2011, 03:07:25 AM »
By request here is a freebee for anyone who needs a differential signal converter board or just wants to mess around with routing a PCB for the fun of it. Traces are best cut with a 30 degree engraving bit at a DOC of only a few thou. then .032" drill and .047" drill. Componets are listed on the drawing. Rev1 does not use terminal blocks. It is meant to have the wires soldered to the board andthen have the whole thing encased in tape or heat shrink and become more or less part of the cable.
No warranty express or implied. Use at your own risk. Routing PC boards is fun and can be addictive. Links to G-code set is at end of post. Setting up a little mill to do engraving is as easy as mounting a die grinder on the head like this:
http://www.youtube.com/watch?v=r9Zf_5yHB1I
www.thecubestudio.com/DifferentialPCB/DifferentialTracesRev1.tap
www.thecubestudio.com/DifferentialPCB/DifferentialDrill032Rev1.tap
www.thecubestudio.com/DifferentialPCB/DifferentialDrill047Rev1.tap
Logged
Print
Pages:
1
Go Up
« previous
next »
