Hello Guest it is November 22, 2026, 02:26:30 PM
Author Topic: Old school work coordinates  (Read 8729 times)
« on: February 11, 2011, 06:50:58 AM »
I have been around a while and have used alot of different systems over the years.
I purchased a system from machmotion for my lathe with version mach3 R3.043.022.
I use GibbsCam 2011 turn and mill in the shop and we use G54, G55, G56, G57, coordinates and so forth for tool location from a set home position.
My question is can I use this same format in Mach 3?
I want to touch off tools enter the amounts in "X and Z" put a G55 or other into the program and go.
If it is possible could someone in layman terms explain how I can go about this IE do this, change that type of thing.
I have been messing around with this for about a week and really need to know if this is possible.
Mark
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Old school work coordinates
« Reply #1 on: February 11, 2011, 09:28:25 AM »
In Mach3 mill go to the offsets page and select one of the fixture (G54-G59) offsets, then go and position your tool, select program run screen and zero out the xy & z dro.
Repeat this for the other fixture offsets you need.
For Mach3 turn you will need to enter the G54-G59 in the MDI line to activate the fixture offset.
Graham
« Last Edit: February 11, 2011, 09:31:18 AM by Graham Waterworth »
